JJP24
Apr 23, 2017Aspirant
Multiple accounts (made a mess), how to delete the unused accounts?
I have three My Netgear accounts (I have made a mess... sorry)
In one account I have a ReadyNAS 104 registered but it has an email address that is about to expire. The email address that I would like to use for this was created as a new account when I bought a WAC501 Access Point but it is still empty.
I have a third account that is also empty registered on my private email account.
I can not find a way to delete the empty accounts. Can somebody please let me now how to do this?
- xiao123NETGEAR Expert
For your email address that is about to expire issue, you can change email address, you can not delete the empty account directly, must contact technical supportor to do it, suggest you change email address to resolve the issue too.
- JJP24Aspirant
Thank you for your answer.
The problem is that the email address I want to use in my account is now in use in one of the accounts I would like to have deleted.
I tried to find a way to contact support about this but no luck. If I select "contact support" I first have to select the device that I want support on (although I don't need support on that device). When I do that I can not contact support because the warranty on my NAS has already expired.
Unfortunately, since your product has expired the free technical support period, if you didn't want to change your email, you must pay for the help of the technical support staff.
- Apr 16, 2020Retired_Member
- Nov 02, 2022Retired_Member
- Aug 04, 2022Retired_Member
