WesleyB
Apr 11, 2016Follower
My Ready NAS Duo will not go into the reset mode.
I have followed the instructions and the NAS RND2110-100NAS will not go into the
Boot menu. All I get is the power button light flashing. Do I have a bad board, or it it operator error? I have tried what the manual says to do and watched what little is on YouTube with out to much help.
- mdgm-ntgrNETGEAR Employee Retired
What problem did you encounter that led to you wanting to use the boot menu?
This is a Duo v1. Did you look at the manual for the Duo v1? - BrianL2NETGEAR Employee Retired
Hi WesleyB,
Welcome to the community!
Did you try this procedure with hard drive/s installed? If yes, how many? I also suggest that you put healthy or fresh hard drive/s that is listed in our HCL.
Kind regards,
BrianL
NETGEAR Community TeamI'm having a similar issue. I had to run a reset since the unit is non-responsive. I've tried reseating the memory.
Now after trying to reset I get the disk 1 LED flashing twice slowly, then the power, ACT and disk 1 LED all flashing together three times quickly. Then repeat.
I've tried resettting but no go.
Any ideas?
- Retired_MemberTry use another browser. I have just tried it and the HCL displays properly for me.
FWIW, to recognize a Duo v1 from a v2:
The v1 is a SPARC unit running RAIDiator 4.1, with a blue and orange GUI. On the front, it's written ReadyNAS Duo. If you have a "v1v2" (version 1 hardware revision 2), the bottom sticker will say RND2000 v2, but it's still a Duo v1.
The v2 is an ARM unit running RAIDiator 5, with a black and grey GUI. On the front, it says ReadyNAS Duo v2. The bottom sticker will say RND2000-200EUS (the last three letters may change depending on the standard of power socket).
