Mikeybr12
Jul 10, 2012Aspirant
NAS Duo (null) folders
Hi, I have a ReadyNas Duo and have recently noted that a few (null) folder have appeard when I open the NAS drive on my smart TV. The folder are not present when I open the folders via the PC. ...
Mikeybr12
Jul 17, 2012Aspirant
Well after several attempts I've managed to cure the (null) folder problem.
All I had to do was resync the volumes.
Front view > setup > volumes > volume settings > resync volumes:
The problem with (null) folder has disappeared.
Hope this helps other with the same issue.
Regards
Mikey B
Regards
Mikey B
