ShadowStorm
Feb 06, 2017Aspirant
Nas is not booking after latest firmware update
After the firmware update it was fine up untill today were it failed to boot, the power light is just flashing (Im sure its just failing to boot)
I have tried to reinstall the OS but his did not work did a little more looking around and there was the OS6 Recovery Tool but can't get it to work, i can select everything else exept the Firmware image
Nas Type: RN102
Drive Space: 2X2TB
Firmware Update: 6.6.1
Thanks to anyone that can help
Just ask if you need anymore information
Then you didn't follow the USB Boot Recovery instructions. In any case this doesn't sound like an issue that USB Boot Recovery is likely to fix.
Have you been getting any SMART errors on your disks?
Have you tried powering down, removing your disks, hooking them up to your PC and testing them e.g. using SeaTools for SeaGate disks and WD Data LifeGuard Diagnostics for WD disks?
- mdgm-ntgrNETGEAR Employee Retired
Have you tried powering down, removing your disks, hooking them up to your PC and testing them e.g. using SeaTools for SeaGate disks and WD Data LifeGuard Diagnostics for WD disks?- ShadowStormAspirant
On one of the disks but a have ordered a repalcement for it the other disk is fine
