mdgm-ntgr's avatar
mdgm-ntgr
NETGEAR Employee Retired
Feb 17, 2015
NAS Not all drives are equal - choosing the right drive for you
One of the most important decisions you will make when purchasing a NAS is the decision as to which drives to purchase to put in it. Indeed depending on which NAS model and which drives you buy you can spend more (or almost as much) on disks as you spend on the NAS itself. It is vital that you get this decision right.
We have a hard disk compatibility list for you to choose drives from: http://kb.netgear.com/app/answers/detail/a_id/20641
Whether the drive has Rotational Vibration Safeguard, the warranty length and the price of the drive can give an initial indication as to the quality of the drive.
Particularly in desktop models with large numbers of drive bays and in rackmount models, Rotational Vibration Safeguard is important. Indeed in the 12-bay models it is essential.
Drives pitched at consumers tend to have shorter warranties. Drives targeted at business users tend to have longer warranties and be designed to handle heavy 24x7 use.
If the NAS is used for primary storage then considering backup storage as well is important. What drives will you use in e.g. a backup NAS?
Budget and capacity requirements are important considerations. Should you go with lower capacity enterprise drives or higher capacity drives targeted at consumers?
Drive choice is very much a personal choice. I would recommend that when you do narrow it down to a handful of options that you may wish to purchase that you do a search for them e.g. using Google and take a look at reviews for the drives to see how other users have found them. Some drives have lower failure rates than others.
If you need help with selecting the right drive for you please ask and the community will be happy to assist.
Do you have any tips for drive selection or an experience you'd like to share or do you have a question about choosing drives for your NAS? Please comment below.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Longer rebuild times or not, backups are still important. If you have another copy or two of your data elsewhere, if you do happen to have e.g. multiple disk failures then you should still be O.K.
  • I thing to keep in mind when choosing drives, is the size of the drive. A Larger drive means longer rebuild times, and therefore an increased risk of errors during a rebuild. That's why I choose 3TB drives for my RN104, and it still takes the best part of a full day to rebuild when replacing a disk.
    mdgm-ntgr
    No. The NAS drives are the better choices. The green ones are "consumer desktop drives" and to be avoided. Green disks have energy saving features which are great for some uses but not for NAS use. The NAS needs to control when disks spin down etc.
  • StephenB wrote:
    In general the new NAS-purposed drives from both Seagate and Western Digital are worth a look, and are (in my opinon) better choices than consumer desktop drives - particularly the "green" ones.).
    Sorry for being a pedant, the above statement appears ambiguous to me :o
    Are the 'green ones' the "better choices" or the "consumer desktop drives" (and hence to be avoided)?
  • StephenB's avatar
    CharlesR wrote:
    I believe Netgear should work in reverse by emphasizing a non compatible list. Which by default would make available which drives do in fact work.
    There is a middle ground here too. Identify some disk drive families that are supported until proven that they are suspect (e.g.,all the NAS-purposed and enterprise-grade drives). Then consumers would have current and safe choices, and Netgear would still have the ability to test consumer drives, SSDs, the new "cold storage" drives.
    I'd agree that the disk manufacturers are winnowed down, which should help. But there are newer technologies (SSDs and SMR) that could have issues with the NAS - and there's probably sound reasons to test green drives carefully.
  • I believe Netgear should work in reverse by emphasizing a non compatible list. Which by default would make available which drives do in fact work.
    Today there are very few hard drive vendors and their lines are reduced as well. Easily broken into categories and I'm guessing one "series" performs virtually the same which greatly reduces the testing variables. Same for the various NAS models... will the 314 really handle drives differently than the 316? I understand they might support different RAID options but on a lower level are the drives really treated differently...
    I think a non approved list is much more valuable than an approved list. You are still going to have an approved list via the drives that are tested and don't fail. So those who want to play the game according to the rules can as in the past. Netgear can even continue to dismiss those who don't if they deem.
    However a good chunk of users who blindly guess at what drive they will purchase will know what to avoid. By only listing drives that are certified Netgear to some degree is endorsing all of the others (by default). They may or may not work... take your chances.
    Now you can pick the above apart if you wish as I really only have two points.
      I see no excuse for not testing the majority of available drives.
      Each of their results should be published as passed or failed.
    The user can decide if increased warranty and other side issues are important to them. Simply let them know if the drive works or doesn't.
  • StephenB's avatar
    Also, if you are particularly bothered by noise (or if the NAS is in a location where noise is bothersome), then you should look for drives that run cooler, and also check the acoustic specs on the drive datasheet.
    Searching this forum on specific drive models is a good idea (and you can do that with google if you add site:readynas.com to the google search string).
ProSupport for Business
