JohnnyViking's avatar
JohnnyViking
NAS placed in addic, can it deal with cold?
Hey, I have placed my ReadyNAS Ultra 4 [X-RAID2] in the addic because of the noise it generates from the fans being always on for some reason. It would otherwise be placed in my home office (below the addic).
Anyway, my question really concerns the chilly conditions up there now that winter is approaching fast. It's basically outside temperatures in the addic. Mid summer probably warmer and I remember seeing the health log of the NAS say it had a temperature of around 60-70c sometimes CPU/SYS. The harddrives was around 50c.
Now, with subzero temperatures outside the CPU is at 20c and SYS at 12c. The harddrives are between 12-14c.
Can the components of the NAS deal with lower temperatures or they at risk dying on me?
  • Here is my Status log from PRO6 by outside temp. 3 C:
    Disk 1 Seagate ST32000542AS 1863 GB , 27 C / 80 F , Write-cache ON OK
    Disk 2 Seagate ST32000542AS 1863 GB , 26 C / 78 F , Write-cache ON OK
    Disk 3 Seagate ST32000542AS 1863 GB , 27 C / 80 F , Write-cache ON OK
    Disk 4 Seagate ST32000542AS 1863 GB , 21 C / 69 F , Write-cache ON OK
    Fan SYS 892 RPM OK
    Fan CPU 2280 RPM OK
    Fan CAS 1854 RPM OK
    Temp SYS 39 C / 102 F [Normal 0-65 C / 32-149 F] OK
    Temp CPU 15.5 C / 59 F [Normal 0-85 C / 32-185 F] OK
    UPS 1 APC Smart-UPS 750, Battery charge: 100%, 82 minutes
  • Mine is:
    Disk 1 WDC WD20EARS-00MVWB0 1863 GB , 14 C / 57 F , Skrivcacheminne PÅ OK
    Disk 2 WDC WD20EARS-00MVWB0 1863 GB , 15 C / 59 F , Skrivcacheminne PÅ OK
    Fläkt SYS 1730 Varvtal OK
    Temp CPU 24 C / 75 F [Normal 0-80 C / 32-176 F] OK
    Temp SYS 14 C / 57 F [Normal 0-65 C / 32-149 F] OK
    UPS 1 Finns inte Ej tillämpligt
    I wonder why my fan is at 1730, and yours is 892.
    How do I get CPU and CAS RPM?
    From the Ultra Specifications @ http://www.readynas.com/?page_id=3962#T ... ifications
    Environmental Compliance
    0 to 40 C (32 to 104 F)
    20% to 80% Humidity (non-condensing)
    This means that ReadyNAS products are tested and certified to work at between 0-40C ambient temperature. So while specific components such as HDD & CPU may be reporting temperatures that are inline with their individual specifications, you may be putting your unit at risk if you place it where the ambient specification is not met.
    Also bear in mind that if you were to shut the NAS down at some point, not immediately restarting it, even the HDDs may be operating out of spec for a while
    Ultimately the choice is of course yours, but I personally would never take the risk of running fragile components like HDDs out of spec
  • Yeah I guess that's the answer I expected. I'll try and relocate it or put some sort of isolation around it so it can keep the temperatures above zero.
ProSupport for Business
