jaykeck
Aug 22, 2011Aspirant
NAS recommendation
I'm looking for a NAS that has 1) 2 network ports with a builtin switch 2) NFS support 3) 1TB of storage or so The 2 network connections are so we can set up a peer to peer connection with tool...
dbott67
Aug 22, 2011Guide
jaykeck wrote: 1) 2 network ports with a builtin switch
None of the ReadyNAS devices offer a built-in switch, however, the ReadyNAS Pro offers dual ethernet ports. The 2 ports can be used for bonding, fail-over or connecting to 2 separate subnets (via static routes).
More info here: http://www.readynas.com/wp-content/uplo ... eaming.pdf
jaykeck wrote: 2) NFS support
All models support NFS protocol, as well as CIFS/SMF, AFP, FTP, HTTP/S and rsync. There's also support for iSCSI and TimeMachine. The Pro models also offer support for active directory.
jaykeck wrote: 3) 1TB of storage or so
Again, all models have the capability to support well over 1 TB of storage. Volume size depends on size and number of disks.
Are you looking for rack-mount or desktop chassis? Do you need Windows Active Directory integration? For desktop models, take a look at the ReadyNAS Pro 4. For rack-mount, have a look at the 2100 or 3100:
http://www.readynas.com/?cat=96
