jaykeck
Aug 22, 2011Aspirant
NAS recommendation
I'm looking for a NAS that has 1) 2 network ports with a builtin switch 2) NFS support 3) 1TB of storage or so The 2 network connections are so we can set up a peer to peer connection with tool...
sphardy1
Aug 22, 2011Apprentice
One thought however - if the tools are on a dedicated subnet, using the ReadyNAS in this manner would not enable direct communication to the tool from the backend network.
If such a capability is required you would have to look at installing a dedicated switch with the NAS. The price of that though is small compared to the NAS + Disks
