Aheagel
Jan 30, 2026Aspirant
Netgear Readynas NVX (Buisness)
I just bought the device for 30 euros and have managed to install the latest official firmware (4.2.31) with Root SSH and fixed the TLS issue. Now I am wondering moving onto flashing something more m...
Aheagel
But it should be possible? My main concern is how to get it to boot to the usb and then how and if the ethernet will be working also what will happen to the lcd?
Sandshark
Jan 30, 2026Sensei
While I've not tried it on an NVX, most units that shipped with RAIDiator 4.2.x aren't picky about the contents of the contents of the USB drive when you choose to boot from USB using the procedure you normally use for USB recovery: RAIDiator-4-2-USB-Recovery-Tool I've successfully booted even MS-DOS on a Pro6 that way. Most do not have a BIOS option to automatically boot from USB, but the NVX may be different.
