Lpilkington75
Dec 29, 2015Aspirant
Netgear ReadyNas rnd 4000 stuck booting #26234791
Dear all I was wondering if anyone can help!? Basically I have a readynas stuck booting! If I remove any of the disks (doesn't matter which one) the device will boot and I get my IP address displaye...
JennC
Dec 29, 2015NETGEAR Employee Retired
Hello Lpilkington75,
Welcome to the community!
May I ask if this is ReadyNAS NV+ v1 or v2? Also, what is the current firmware?
When removing disks, please make sure to always put the disk to the same bay where you removed it from, the disk order is very important. We are not sure yet if it still has data, if you can access the FrontView, get to Volume then Volume Settings. This will show the disks and RAID configuration, please post here the screenshot.
