Lpilkington75
Dec 29, 2015Aspirant
Netgear ReadyNas rnd 4000 stuck booting #26234791
Dear all I was wondering if anyone can help!? Basically I have a readynas stuck booting! If I remove any of the disks (doesn't matter which one) the device will boot and I get my IP address displaye...
Lpilkington75
Jan 17, 2016Aspirant
If i replace disk 3 should the RAID automatically build the missing data on the new Disk 3
JennC
Jan 21, 2016NETGEAR Employee Retired
Hello Lpilkington75,
It should, but as mdgm mentioned there could be another bad disk so that might not be a good idea. You might need to get data recovery service.
