Paul-Jan
Apr 08, 2016Tutor
Netgear why ? does nothing work, Readycloud, ReadyNas
Components: Router R7000,ReadyNasDuo RND2000, PC’s Windows 10 prof. 64 bit What do I want; just share a drive over the internet for sharing. With ReadyCloud I can’t 1) ReadyCloud don’t support th...
- Apr 08, 2016
WOW, a disabled Jumbo file’s on the NAS and un- installed ReadyNas Remote re-installed it and , Yes on my Windows 10 PC the NAS and the USB drive connected to the Router R7000 pop-up !
I even can read and write on the shared folders… on the NAS and on the USB drive.
Was the check box for Jumbo files the issue ?
JennC
Apr 08, 2016NETGEAR Employee Retired
Hello Paul-Jan,
Which storage are you really trying to use and share over the Internet? Is the ReadyNAS Duo or the USB stick you plug in to your router?
ReadyCloud will not work with the legacy ReadyNAS unit you have, it works with ReadyNAS OS6. If you want to use ReadyCloud, you can only use it with your router with USB stick.
Paul-Jan
Apr 08, 2016Tutor
It doesn’t matter, something, ore the USB Drive or my NAS, one of them will do.
But so far I can’t do it with ReadyCloud en it won’t work with ReadyNas Remote.
(I wrote ReadyNas, it is ReadyNas Remote)
Yes I have created an account, en Yes It is working on a Apple ! But not on a Windows PC.
Currently I’m trying it on an old Windows XP latop, no success………..
