Paul-Jan
Apr 08, 2016Tutor
Netgear why ? does nothing work, Readycloud, ReadyNas
Components: Router R7000,ReadyNasDuo RND2000, PC’s Windows 10 prof. 64 bit What do I want; just share a drive over the internet for sharing. With ReadyCloud I can’t 1) ReadyCloud don’t support th...
- Apr 08, 2016
WOW, a disabled Jumbo file’s on the NAS and un- installed ReadyNas Remote re-installed it and , Yes on my Windows 10 PC the NAS and the USB drive connected to the Router R7000 pop-up !
I even can read and write on the shared folders… on the NAS and on the USB drive.
Was the check box for Jumbo files the issue ?
Paul-Jan
Apr 08, 2016Tutor
It doesn’t matter, something, ore the USB Drive or my NAS, one of them will do.
But so far I can’t do it with ReadyCloud en it won’t work with ReadyNas Remote.
(I wrote ReadyNas, it is ReadyNas Remote)
Yes I have created an account, en Yes It is working on a Apple ! But not on a Windows PC.
Currently I’m trying it on an old Windows XP latop, no success………..
Paul-Jan
Apr 08, 2016Tutor
- mdgm-ntgrApr 10, 2016NETGEAR Employee Retired
In my view using Jumbo Frames is more trouble than what's it worth as you need all your hardware to support them, be configured to use them and to set the right MTU value. However for some use cases they work well.
