JMEAST
May 04, 2017Aspirant
NetgearRN212 offline. Can't access readycloud
I moved the NAS into a different office room and internet is connected via a different access point in the wall. I now can't access NAS as it just says Offline. I urgently need to have access to read...
- May 05, 2017
Hi all
I finally got an IT guy in and he reckoned I'd plugged the network plug in the wrong hole at the back of the NAS. After much restarting and reinputting passwords, it finally worked. I hate technology!
JMEAST
May 05, 2017Aspirant
It says ON.
May 05, 2017Guru - Experienced User
And you are seeing confirmation of both internet and cloud service on the cloud page of the web ui?
Also, what firmware are you running.
- JMEASTMay 05, 2017Aspirant
Hi all
- StephenBMay 05, 2017Guru - Experienced User
JMEAST wrote:
Hi all
Both ethernet ports function identically, but they might have been manually configured differently in the NAS. Also your enterprise firewall rules or DHCP server might be set up for one specific NIC.
Anyway, I'm glad you got it sorted out. You might stick a label on the back of the chassis, to prevent this from happening in the future.
label already stuck on !
