jholden
Jan 27, 2017Aspirant
Network connection drops after a few hours.
My ReadyNAS Pro6 drops network connection every so often, it started happening after the last firmware update to RAIDiator 4.2.30. It works fine after I reboot it, then it drop all netwrok connectivi...
Jan 28, 2017Guru - Experienced User
4.2.28 is here: http://kb.netgear.com/30002/RAIDiator-x86-Version-4-2-28 I don't think 4.2.29 was ever released (it just stayed in beta forever).
Have you checked for a full OS partition? You would need to enable ssh with the add-on in order to check.
- jholdenJan 29, 2017Aspirant
I've tried that firmware and several lower, down to RAIDiator 4.2.27, all of them yeild the same results. I'm convinced it's a hardware issue since no other settings have changed in the configuration.
- StephenBJan 29, 2017Guru - Experienced User
A filling OS partition can also create this symptom. Though often that also causes the firmware downgrades to fail.
But if you want to check for that, you can enable ssh and tell very easily if that's the problem.
you'd install the Enable Root SSH add-on from here: https://kb.netgear.com/24551/ReadyNAS-Add-ons-for-RAIDiator-4-2-x86?cid=wmt_netgear_organic
Then either install putty (windows) or use terminal (mac) to ssh into the NAS over the network. User name is "root", password is the nas admin password.
Then enter
df . -h
df . -i
and report back on the results.
You do of course have two ethernet interfaces, so you could also try switching to the second one.
df . -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 499M 3.3G 13% /
df . -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/md0 65536 11231 54305 18% /
