bruceread's avatar
bruceread
Network Credentials External Drive on ReadyNAS 102
I have a ReadyNAS 102 with an external hard drive plugged into one of the back USB ports. The drive is visible within Windows File Explorer in the list of ReadNAS folders. When I click on the external drive ("usb_hdd_2") I am prompted to enter my Network Credentials. I have tried all sorts of combinations of user name and passwords and consistently get a message that I may not have permission to access the drive.
- Two screen prints are attached that show the credentials request and the response.
- I can access the external drive and all its files from within ReadyCloud.
- I can access the other ReadyNAS folders and files within File Explorer.
- I've looked for explanations online and have tried a few, but no luck so far.
- Does anyone know how I can solve this Network Credentials mystery?
Thanks!!  Bruce
  • StephenB's avatar
    I'm not seeing your screenshots.
    Perhaps look at the share settings (both network access and file access) for the USB drive share, and compare them with the settings you see on the shares you can access.
    • bruceread's avatar
      bruceread
      Here's the file with the screenshots!
      • StephenB's avatar
        Thx.  The advice is the same though.
      bruceread
      Stephen, I worked on this Network Credentials problem some more and was able to get access to the an external hard drive that's connected to one of the ReadyNAS's USB ports.
      - In the ReadyNAS Admin page, on Network Access for the external drive settings, my username setting is checked (this was the case before)
      - In the Windows Network and Sharing Center, on the Advanced Sharing Settings page, "Turn on file and printer sharing" is selected (I think this is what did the trick for me)
      - In Windows File Explorer, when prompted for Network Credentials after selecting external drive in ReadyNAS folder list, I used my ReadyNAS user name (happens to be the same as my Windows account name) and the ReadyNAS password (I had tried this combination before without success)
      So it seems that the sharing setting in the Windows Network and Sharing Center was the missing key for me.
      Thanks for your help!
      Bruce
ProSupport for Business
