Asto
May 21, 2017Aspirant
New drive - Volume degraded
Hi, I have had a RN102 with a 3TB Segate drive working happily for several years. I recently added a 3TB WD Red drive, so that I have redundancy protection. ON power up, it starts to synchronise but...
May 21, 2017Guru - Experienced User
Asto wrote:
Channel: 1
Model: ST3000DM001-9YN166
Serial: W1F1YZYN
Current Pending Sector Count: 1176
The disk swap isn't the problem. The Seagate disk is failing (1176 bad sectors so far).
So
- make a backup right away
- replace the Seagate DM drive
- Do a factory reset with the two new drives
- restore data from the backup.
JBDragon1
May 22, 2017Virtuoso
YA, that was one of my guesses. A bad Seagate drive. They just don't tend to last. Also when you pop in a new drive and the NAS has to do a rebuild, that puts extra stress on the other HDD(s). That tends to be the time a HDD is going to fail on you. Which is one reason why you should have a backup. At least the 3TB drives are reasonably priced. Though HDD prices arn't dropping down fast enough.
