paulsb01
Sep 28, 2020Aspirant
New drives. Not fully accessed
I took my old rdn4000u and out of storage as I want to use it as a back up. I Iinstalled 2 8tb drives after multiple tries, etc. erasingwith radar, etc it only sets it up a 1.3 tb. This is a 4 bay un...
- Sep 28, 2020
paulsb01 wrote:
What is the best way to set this up for 2) 8tb drives.. one to mirror the other in case of failure.
Do I use the pin hole on the back of the NAS and if so, which setting?
What you need is to do a factory default.
It is possible to do this with the reset pinhole, but the simplest way is to use the admin web interface (https://nas-ip-address/admin )
Choose System, and then Update from the left menus. Then select the "factory default" tab in the center, and then "Perform Factory Default".
The system will likely ask for confirmation (it's been a while since I did this), and then when it boots up it will automatically create a RAID-1 array. The ReadyNAS will be syncing the array for a while, but you can configure it during the process. Note you can also start loading it with data, but it will go faster if you wait for the array to be built.
Sandshark
Sep 28, 2020Sensei
There is no such thing as a "rdn4000u". But I think you have an RND4000-100, which is an NV+ V1. If it's silver in color, that's what it is (regardless of any sticker that has another version number on it).
The maximum drive size on an NV+ V1 is 2TB, and it is a hardware limitation, not firmware. 1.3TB is what's seen when the system ignores the highest order bits in the reported drive size.
If you have an RNDU4000 or RNDP400U, which are black in color, then you would have to have really ancient firmware to have a 2TB limit per drive.
Sep 28, 2020Guru - Experienced User
You'd need at least 4.2.12 to get support for 4K sector drives. But if you have an ultra or pro, you should be running at least 4.2.31 anyway, so I suggest upgrading to that.
However, you'd still only be able to expand the array to 3x8TB - there is a 16 TiB volume limit in 4.2.x firmware. So a better strategy would be to first update to 4.2.31, and then convert the NAS to run OS-6.
- paulsb01Sep 28, 2020Aspirant
Thank you.. you are reffering to the RADAR or the firmware in the NAS itself? We are only useing 2 8tb drives.
