ponchoman
Nov 30, 2011Follower
New ReadyNas system, existing drives with data
Good afternoon, I was looking forward to purchasing one of the readynas devices, but I had 1 question. I have 2 500GB SATA drives in a linux box (ext 3, mirror via rsync) that I'd like to use in t...
tropicalicecube
Dec 15, 2011Aspirant
Hello,
Please allow some very slight threat hijacking here, as my issue is practically the same but not being native English speaker, I'd gratefully get some more details on the above procedure.
My data is in a Taurus Gigalan; the disks are currently healthy, but I am not happy with the machine, then that's OT.
On my desktop I have been moving RAID1 arrays all the time, be it from machine to machine or from one Linux distro to another, but it seems not so simple with NAS?
If I understand well, you recommend this procedure:
0. Data is safely in your hardware, identical on 2 drives that we'll call sda1 and sda2.
1. Remove one of your 2 disks in your current hardware, call it sda2,
2. Set sda2 up in the new NAS, as a single unit, not redundant machine.
3. Start copy procedures between sda1 on former hardware and new NAS where sda2 sits; go do something else.
4 move the remaining sda1 disk from former hardware to NAS, set it up as mirror/new member of raid array, and go do something else again while the NAS syncs from sda2
Would that work?
can I just use rsync like in 'rsync -rluv root@OLDNAS:/my/folderrs/* root@NEWNAS:/my/folders' with the Duo?
Can I build the the RAID array after doing the copy with only one disk in the NAS?
Would the NAS accept sda1 as a "new" disk to include in a RAID1 array?
Cheers
Jean-Philippe
Below, my current partition table in my cheap thingy:
NASPAS> fdisk -l
Disk /dev/hda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Boot Start End Blocks Id System
/dev/hda1 1 66 530144+ fd Linux raid autodetect
/dev/hda2 67 121569 975972847+ fd Linux raid autodetect
/dev/hda3 121570 121601 257040 82 Linux swap
Disk /dev/hdb: 1000.2 GB, 1000204886016 bytes
Device Boot Start End Blocks Id System
/dev/hdb1 1 66 530144+ fd Linux raid autodetect
/dev/hdb2 67 121569 975972847+ fd Linux raid autodetect
/dev/hdb3 121570 121601 257040 82 Linux swap
It's all still ext2 AFAIK.
Would that work?
Cheers
Jean-Philippe
NASPAS> fdisk -l
