profeta64
Apr 06, 2020Luminary
New ReadyOS 6.10.3 and usb encryption
Hi to all, I see in the setting menu a new entry: "usb encryption" Did I miss it before or it is a new feature? How does it works?
Sandshark
May 20, 2020Sensei
OK. I understand that your hand is being forced. But keeping a backup offline means it's not going to be kept up to date as well. What are you doing, "sneeker net" with a USB drive?
Being locally online does not mean the NAS has to be available via the Internet. You can have a separate router (or just a switch or direct wiring if you use static IPs) for the second port of your main NAS that connects to the backup and has no internet access. Of course, VLANs can do much the same thing, but many IT security people know security but very little about IT or don't think paractically. Like arcane pasword requirements that pretty much force you to write them down -- is that really more secure?
profeta64
May 22, 2020Luminary
Please do not go off-topic.
Anyway, you would need another ReadyNAS, and of the key in order to get access to the data.
It could be that several cases, where I would heave the need to get access to the data froma Windows/MAC computer.
i.e. my nas is damaged, I need now access to the data
- StephenBMay 22, 2020Guru - Experienced User
profeta64 wrote:
It could be that several cases, where I would have the need to get access to the data from a Windows/MAC computer.
I agree, that's an obvious need. If it can't be done natively, there should at least be a VM that can be used to access the data.
- SandsharkMay 22, 2020Sensei
StephenB wrote:I agree, that's an obvious need. If it can't be done natively, there should at least be a VM that can be used to access the data.
I've never tried to use encryption with the ReadyNAS VM, or even assign a USB port to it. I've never tried USB drive encryp[tion on a real RedayNAS, either, since it's new and I don't have a need for it. I use Veracrypt for all my encryption needs, which I run on a PC and have the target file on the NAS. But I just keep a few thigs like tax files and such in it.
This sounds like a worthwhile experiment for somebody to run. I'm afraid I may not get to it before the OP needs to make a decision, though I'll put it on my list.
- SandsharkMay 24, 2020Sensei
The ReadyNAS VM does not recognize when a USB drive is connected to it, so that's apparently not an option. It's there and can be manually mounted, but it doesn't show up anywhere in the GUI. If there is a way to trigger the OS to see it like it does a newly inserted one on a real NAS, then maybe it would work.
Digging a bit more, I note that LUKS is installed on a ReadyNAS, so i rather expect it's being used for the encryption. If it is, then perhaps LibreCrypt could access it.
- StephenBMay 24, 2020Guru - Experienced User
Yes, I believe it is. But there are a couple of ways that can be set up - it would be helpful if Netgear published a procedure for manually mounting an encrypted volume.
