skeleton567
Apr 18, 2019Aspirant
new RN21400 RND-4E Do I have to format drives being inserted
Have just unpacked new unit. Can I safely insert currently populataed SATA drives that contain valuable data, or do they HAVE to be reformatted? I do not need RAID at this point, and just want my d...
- Apr 18, 2019
Well, thank you for the replay. Unfortunately, I just printed the return shipping label. This appeared to be a great solution, but I have 4 sata drives that are already populated. It seems I can't just populate the drive bays and use them as they are as network shared drives. I use off-line storage for backups. I would use this device if it didn't require that I 'start from scratch'. I've used WD products for many years, and am sorry this one doesn't meet my current need.
Apr 18, 2019Guru - Experienced User
The NAS will format the disks even if you aren't using RAID. So any data on them will be lost.
skeleton567
