la5vsa's avatar
la5vsa
NV+ & 3TB Drives
Hi.
Just tryed to install a NV+ for an company.
I replaced 2 X 1TB drives with 4 X 3TB drives, factory reset & changed to raidlevel 5.
But it can only see the drives as 1tb drives...
Am running firmware release 4.1.14
The disks is WD Red 3TB NAS Harddrive SATA 6Gb/s (SATA 3.0), 64MB, 3.5", 24x7 reliability
Is it a limit on disk size on this NAS NV+ ?
Regards
Bjørn
  • Hi Ixa, and thx for quick replay :)
    oki, then i have to replace the nas..
    Other model from Netgear i can use my drives ?
    Regards Bjørn
    I recommend you the Intel-based ReadyNAS OS 6 models like RN314. Check the specs here: http://netgear.com/images/pdf/ReadyNAS_ ... 700_DS.pdf
    Be sure that you have a backup of the data from your NV+ v1 so that you could just restore it if ever you have purchased a new ReadyNAS OS 6 model.
ProSupport for Business
