esmadja
Aug 28, 2011Aspirant
NV+ and 3TB HD
Will the ForceExpansion add-on enable the ReadyNAS NV+ to run with 3TB drives? I am running the 4.1.6 Firmware release. I currently have 1.5TB Seagate drives and want to expand to 3TB drives. Is ...
mdgm-ntgr
Sep 14, 2011NETGEAR Employee Retired
Well as a fellow ReadyNAS user, I could only guess, but I think it's highly unlikely the situation will change.
x86 ReadyNAS (e.g. Ultra, Pro) support 3TB drives. I would suggest getting one of these and transferring your data across your network to it (you can't migrate disks from Sparc to x86).
