SJMarty
Nov 28, 2013Aspirant
NV+ Drive Trays
I have an NV and an NV+. My NV has the first generation drive trays that stick. My NV+ has the newer black trays that do not stick. I would like to replace all four of the trays in my NV with the n...
Nov 28, 2013Guru - Experienced User
This is the correct part number. If you search with google shopping, you will find some stores that carry them. One that seems relatively inexpensive (including shipping) is
http://www.2020pc.com/ssproduct.asp?pf_ ... 7AodvmkArw
I've never purchased from them btw...
