whipartist
Jul 22, 2014Aspirant
NV+ failed power supply, best course(s) of action?
I have a ReadyNAS NV+ labeled NV4000 v3 but everything I've read suggests that it's a v1. I can't remember when I bought it. All indications are that the power supply is blotto, to use a highly tech...
whipartist
I'm not 100% certain how they were formatted, but in thinking about it they are almost certainly ext3. I've tried ext2fsd on both an XP and a Vista box, but it just shows the partitions as RAW. explore2fs on XP finds nothing whatsoever, though I'm not sure I'm using it correctly... I haven't tried it on the Vista box yet.
Oh hey... I have a rackmount server downstairs that probably has a USB port. I'll fire that up tomorrow and see if I have any luck. if I can read the larger of the USB drives then I'll be a happy camper, since that should be a 100% backup.
