TieNN89
Oct 30, 2011Aspirant
NV+ Fan
Hi all I'm finding the fan in the NV+ a little bit too noisy for my liking So I was thinking about replacing it I have looked into the specs of the stock fan and here is what I found out ...
PapaBear1
Nov 01, 2011Apprentice
I can't help you as my NV+ is still running the original fan and it has never bothered me. In fact the drives are louder than the fan. As long as it is the same connector on both fans, then it should control it to some extent. There have been some discussions about this in the past, but I don't have links to them. You can try searches. Of course it does void the warranty if you still have any.
