TieNN89
Oct 30, 2011Aspirant
NV+ Fan
Hi all I'm finding the fan in the NV+ a little bit too noisy for my liking So I was thinking about replacing it I have looked into the specs of the stock fan and here is what I found out ...
TieNN89
Nov 21, 2011Aspirant
Whoops forgot to reply to this
I ended up replacing it with the Noctua NF-P12 120mm fan with a 92mm to 120mm fan adapter
I was going to go the B9 but wasn't sure if the air flow was enough so I decent to go that route instead
Last I checked the CPU was around 38C and the HDD was around 36C this is a few mins into it transferring files and in a room that is sitting around 30C and I'm expecting my room to get even hotter as the summer approaches
