oscarthecat
Nov 11, 2013Aspirant
NV+ memory upgrade
Hi,
i recently bought a NV+. Is it possible to upgrade the memory with a so-dimm?
Which memory should I use? Is there a how to guide?
Thanks for your efforts!
- StephenBGuru - Experienced UserDo you have a v1 or a v2? Use the guide here: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
- oscarthecatAspirantHi Stephen,
it is a V1 NV+ - mdgm-ntgrNETGEAR Employee RetiredO.K. You could replace the memory (not supported). There are replacement instructions in the FAQ. Get memory that matches the specs and physical appearance of the stock module as closely as possible.
