drell
Apr 21, 2012Aspirant
NV+ to Pro
I have a ReadyNas NV+ 4 disc unit and a Pro 6 disc unit. The NV+ is older and I want to get a second Pro to replace it and get more storage space. Can I take the NV+ discs and put them into the Pro t...
TeknoJnky
Apr 21, 2012Hero
drell wrote: Can I take the NV+ discs and put them into the Pro to save migrating data across my network?
No.
I've seen some conflicting info on the forum, so I'm not sure if the disc swap is possible (would prefer that over moving the data).
You can surely reuse the disks, however you must move the data across the network (or to usb drives) if you wish to keep it.
The pro will *not* read the nv+ disks, they will be erased and reformatted.
