drell
Apr 21, 2012Aspirant
NV+ to Pro
I have a ReadyNas NV+ 4 disc unit and a Pro 6 disc unit. The NV+ is older and I want to get a second Pro to replace it and get more storage space. Can I take the NV+ discs and put them into the Pro t...
ReadySECURE
Apr 21, 2012Apprentice
TeknoJnky is correct. I only want to add that you should cross reference the Hardware compatibility list to ensure that your NV+ disks are in fact usable with the Pro. here is the link for your reference: http://www.readynas.com/?page_id=82
