Charles_R
May 19, 2012Aspirant
NV+ v2 with WD30EZRX
I purchased both of the above on May 7th via a Amazon bundle (for a great price) and when I purchased them I'm 99.99% sure the drive was listed as compatible with the NV+ v2. Installation went fine an...
gandalfnet
Jul 10, 2012Aspirant
http://www.readynas.com/?cat=19
You have to Down grade to 5.3.4 or earlier,
If you open up a ticket it will take hours of your life away for them just to tell you to replace your drives because they are NOT on the list..
I went through it all with them and finally I was the one that I told netgear the fix was go to back in the firmware to 5.3.4 or earlier.
