daztrue
Apr 27, 2017Aspirant
NVX Business Edition RNDX4210 won't power on
I recently powered down NVX and removed cables and bays before unscrewing and removing sides and top covers and cleaning dust with compressed air can. I've done this successfully before, following a ...
- Apr 28, 2017
The cheapest way is to modify the cable pinout yourself to adapt it to the NVX. http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
This isn't the cheapest, but avoids that hurdle and should fit: http://www.evercase.co.uk/CompatibilityListReadynas.htm £60 excl VAT&PP
Sandshark
Apr 27, 2017Sensei
It's possible you damaged something, but probably not with the air. Maybe bumped into something?
Or, and it sounds a lot like it could be this, it's not something you did other than turn it off. If the power supply is going to fail, it's usually going to do so on a power-on attempt. Same with a lot of other possibilities, but an NVX power supply is a little long in the tooth and a very likely candidate. The count of failed NV+ PSU's is growing here, and the NVX uses the same one and is of a similar generation.
