daztrue
Apr 27, 2017Aspirant
NVX Business Edition RNDX4210 won't power on
I recently powered down NVX and removed cables and bays before unscrewing and removing sides and top covers and cleaning dust with compressed air can. I've done this successfully before, following a ...
- Apr 28, 2017
The cheapest way is to modify the cable pinout yourself to adapt it to the NVX. http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
This isn't the cheapest, but avoids that hurdle and should fit: http://www.evercase.co.uk/CompatibilityListReadynas.htm £60 excl VAT&PP
daztrue
Apr 28, 2017Aspirant
I'm not able to upgrade or migrate right now due to finances and the fact that my NVX (my only NAS) won't power up, plus I need to get it running as soon as possible.
Sandshark, after posting initially I checked a few threads on the same issue, including posts by yourself, with mention of and link to correct PSU, setup, price, specs etc. I can't remember what was where or what applied to me. I'm UK based, if relevant to purchase and/or compatibility. If you could provide the best (and hopefully cheapest!) link to the specific PSU required, as well as required specs, it would be a god-send!
I recall reading nightmare details of PSUs that didn't quite fit, followed by mention of aluminium, duct tape, drilling holes in the casing. I have to avoid all of this at all costs!! :smileyfrustrated:
Darren
mdgm-ntgr
Apr 28, 2017NETGEAR Employee Retired
If the disks are fine, the array is fine and the volume it should be straightforward to use an ordinary x86 Linux machine to read the data at your own risk. You would need to install mdadm and lvm2 if they are not pre-installed. You should check disk health and the state of the RAID before trying to start the RAID using mdadm. Then scan for the volume group, activate the volume group and mount the volume read-only and backup the data.
You have multiple different options. For many using a new x86 ReadyNAS to mount the volume read only and backing up the data as explained in the article I linked to above would be simplest.
