TravisBanger
Nov 04, 2014Aspirant
Ordering a ReadyNAS with any disk EXCEPT Western Digital?
I would like to replace my current ReadyNAS which contains 4 disks with a more recent model. Is there any way I can specify the disks as ANY BRAND except Western Digital? TIA
TravisBanger
Nov 05, 2014Aspirant
vandermerwe wrote: If you are set against a specific disk manufacturer then why is it that you won't buy your own disks? There are only disadvantages to purchasing populated units from your perspective, and it may be more expensive.
Thanks. I will follow your advice.
