ayairo's avatar
ayairo
Follower
Oct 07, 2016
OS6.5.2 → 6.6.0 after the update, Volume is no longer recognized
Or what did you do to can not be downgraded
What would it happened in the update
  • ayairo,
    Your situation looks like a data recovery one. You should contact support if you are interested in purchasing a data recovery attempt.
    I noticed that you moved your disks to an x86_64 model (which one?) and then back to your ARM box.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Can you send in your logs (see the Sending Logs link in my sig)?
      mdgm-ntgr
      ayairo,
ProSupport for Business
