davidr1
Mar 03, 2022Luminary
OS6 DISK TEST STILL GOING AFTER 4 DAYS
Hi
NAS 314 4x4TB RAID 5
I started a Disk Test Mar 01, 2022 13:45:01 Volume: Disk test started for volume data
It is still going (Mar 04 09:11)
The only indication anything is happening is the ACT light every 7 seconds or so and the Admin Page > System > Volumes which dims and has a sliced circle rotate when disk activity occurs.
How can I stop the test? Should I?
Many thanks,
David
- davidr1Luminary
Any help at, please? It's still going Mar 05 09:06
Many thanks
David
It's certainly running much longer than expected. My 4x10 TB system completes the disk test in less than 24 hours.
My recollection is that there is cancel control on the volume page - not sure about that though. Rebooting is another thing you can try.
After cancelling, it makes sense to download the full log zip file - looking to see if there are errors that might explain the slow completion.
- davidr1Luminary
Hi StephenB,
Many thanks for your reply.
There is no Cancel button (6.10.6) on the Volumes page. So I did a Shutdown and it powered down straight away. A Cancel option on the page would be a good idea.
The disks are WD40EFAX and supported. I'll download the log.
Is it the DISKS log?
Many thanks,
David
