StephenB's avatar
"Partial" factory reset
Thinking about the 8 TB expansion limit...
My Pro has Crashplan installed, I imagine there are many here who have installed more stuff. It would be painful to reinstall everything.
It would be very nice if you could delete/recreate your volumes without starting over on the OS. Since this is most useful for folks who are using SSH, it would be ok if it were an SSH/command line procedure.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Can't you already do this via Frontview if you're using Flex-RAID?
  • StephenB's avatar
    I'm using XRAID-2
ProSupport for Business
