MajorMatt
Jan 23, 2014Aspirant
Power cut to Duo, now unable to access
My ReadyNas Duo v1 experienced a loss of power a few days ago and after rebooting it I am unable to access it or detect it in RAIDar. When the device powers up the blue power indicator blinks, act fla...
Jan 23, 2014Guru - Experienced User
What you tried was a factory reset. If you succeeded, you have already lost your data. Hopefully you failed.
If you have a Windows PC (and can connect drive 1 via SATA or a USB adapter) you can try linux reader (http://www.diskinternals.com/linux-reader/)
