kevinngeorgia
Feb 08, 2012Aspirant
Power is out of spec
Just got a warranty replacement ReadyNAS 1100 and Im getting a "2.5v power is out of spec"
2.5v power is out of spec [expected: 2.5 current: 4.080].
[Wed Feb 8 09:00:31 PST 2012]
Do I need to call and get the warranty replacement "replaced" ?
Thanks for your Help,
Kevin
Kevin
1 Reply
- PapaBear1ApprenticeI would recommend you contact technical support and work with them. You may want to refer them to your original case number and RMA number.
