pumpchump
May 19, 2017Aspirant
Power loss
I'm experiencing power loss to my NAS. What should I check first the power supply on the cord, or presume the power source inside the NAS has failed.
pumpchump
May 22, 2017Aspirant
It's a ReadyNAS Ultra II. I'd say that I've had it since 2011.
May 22, 2017Guru - Experienced User
The warranty is 3 years
If you are seeing no lights and hearing no fan noise then it is most likely the power brick. If you google it, you will find some compatible bricks.
