tminimax's avatar
tminimax
WAC505 looses configuration after power loss
Hallo,
i´m using a WAC505 AccessPoint which is powered through POE. Everything is working perfect, but if i encounter a power loss, the configuraton of the wac505 is also lost. what is wrong? i'm using it in standalone config mode - no cloud...
is the ap broken?
thanks for any help
  • yes, factory default. so i opend a replacement call at netgear support
    the exchange the ap to a new one.
    now everything is working
    it seems that the config could not stored permanently in the chips
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi Thomas Minichmayr
    Welcome to the Netgear Community. Do you know the firmware version that AP is running?
    Does this happens when you do manual reboot from UI?
    Does this happens when you connect AP with external power supply and reboot happens because of power shutdown?
    Thanks
    Raghu
    • tminimax's avatar
      tminimax
      Hi,
      the firmware is the latest (i think): V3.1.0.12
      no power supply used (because shipped without) --> connected via netgear poe switch
      on manual reboot the config is still available!
      only if i disconect the ethernet cable oder power of the switch - the config is lost!
      • RaghuHR's avatar
        RaghuHR
        NETGEAR Expert
        Could you please save the detailed logs from monitoring page and send it for us to debug?
        Thanks
        Raghu
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Can you share the switch model details that you have connected your AP?
    • tminimax's avatar
      tminimax
      the switch is a dlink (not netgear), modell DGS-1008P from d-link
      other poe devices are working ok - e.g video surveillance cams...
ProSupport for Business
