pumpchump
May 19, 2017Aspirant
Power loss
I'm experiencing power loss to my NAS. What should I check first the power supply on the cord, or presume the power source inside the NAS has failed.
JennC
May 22, 2017NETGEAR Employee Retired
Hello pumpchump,
I checked your profile and found that the ReadyNAS Ultra 2 that you have registered is already out of warranty.
You might want to buy power adapter from support team.
Welcome to the community!
Sandshark
May 22, 2017Sensei
I agree, probably the power brick. You may even already have a compatible one lying around. It's a 12V, 5A supply and uses the typical connector for that. Most any supply with those specs (or even more current) will work. 12V surveillance cameras use the same connection. If you have something with just a couple amp capability, you conld see if it will power it up without the drives installed, just to verify it's the supply before buying another.
