Sugru's avatar
Sugru
Power supply replacement Ultra 4
I've had a Ultra 4 stored unused for the last few years. When connecting it to power today, the power supply died violently( blowing my 16A circuit breaker for the room).
I took the power supply out, it's a "FSP060-40LE" 60W fanless unit.
When I saw the connection bein a standard 20 pin, I connected a 500W ATX power supply I had lying around, and the Ultra 4 booted normally.
Searching for a replacement power supply that would fit inside the cabinet I found some previous threads saying that the atx connector should be wired differently..
Is there different hardware versions for the Ultra4? The model no is RNDU400-100PES, TA 100-15335-01R8
My main question is, can I run it with the ATX power supply, insert some spare disks and use it for temporary data migration as intended, or do i risk the whole unit failing on me now?
  • If it's just to migrate the data, I recommend you buy an ATX power extender and just clip the -5V and -12V lines.  Or, if the supply is "expendable", just clip the wires directly.  Your unit will probably run fine on a standard ATX supply without the extra +12V long enough for you to extract the data.  Of course, you may have already killed the -5V and -12V on that supply by mating them with +12V in the NAS.
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hi Sugru,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Thanks,
    • Sandshark's avatar
      Sandshark
      Sensei
      • Sugru's avatar
        Sugru
        Hi, thanks for the advice, I have an atx extender cable on order, so will modify that when it arrives and power up again..
        I guess I'll have to see what happened to my power supply, it doesn't have any -5V as pin 18 is unused on newer ATX power supplies, so it's the -12V that may be the issue.
        The important bit is that my Ultra 4 mainboard should be ok?, even though I connected the ATX supply before I knew the wiring was modified..
        I see the comment above about FSP120-40LE, the original power suplly on my Ultra 4 is an FSP060-40LE, 60W, but the wiring does indeed match the pinout with regards to colours..
  • mdgm-ntgr's avatar
    mdgm-ntgr
    ReadyNAS Ultra 4 PSU is modified FSP120-40LE. The pinout is different from standard ATX PSU where -12V and -5V are used for 12V.
    Unless your PSU does not output -12V/-5V, a standard PSU can’t be used.
ProSupport for Business
