ludo2505's avatar
ludo2505
Follower
Oct 29, 2025
Prb sur une baie Nas 10400
Bonjour,
J ai un souci sur mon nas rn10400,
J ai la baie 3 qui n alimente plus mon disque.
Lorsque je mets un disque qui fonctionne sur la baie 1,2,4 sur la baie 3, je vois que la baie 3 n alimente pas mon disque, et donc n est pas reconnu sur la baie 3, quelqu un a déjà eu ce problème?
Merci
1 Reply
  • StephenB's avatar
    We've sometimes seen bays fail here (either power or SATA).
    Unfortunately this is not repairable.  Note Netgear has exited their NAS business
    Options are
    1. to get a compatible used ReadyNAS and migrate the disks
    2. do a factory reset with three larger disks, and restore the data from a backup
    3. replace the NAS with a new model (different manufacturer).
    On (1) - the most recent ReadyNAS platforms were launched in 2017, (therefore compatible ReadyNAS are 8+ years old).  IMO, this is not the best option for you, though it might be the simplest one.
ProSupport for Business
