rocus
Jun 09, 2015Aspirant
printer not found
When I attach an usb printer to a Readynas Duo I expect to find the printer in the frontview menu under printers.
I don't see one. What can I do to check what is wrong. I installed the enable root addon. lspci shows 3 usb that seem to work.
lsusb is not present.
A tail from the messages file shows this:
Jun 9 18:54:28 backup kernel: usb 1-2: USB disconnect, address 3
Jun 9 18:54:28 backup kernel: drivers/usb/class/usblp.c: usblp0: removed
Jun 9 18:54:28 backup kernel: USB: Canon iP3600 series printer disconnect.
Jun 9 18:54:34 backup kernel: usb 1-3: new high speed USB device using ehci_hcd and address 4
Jun 9 18:54:34 backup kernel: usb 1-3: configuration #1 chosen from 1 choice
Jun 9 18:54:34 backup kernel: drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 4 if 0 alt 0 proto 2 vid 0x04A9 pid 0x10CA
Jun 9 18:54:34 backup kernel: USB: Canon iP3600 series printer connect.
Here I disconnect the printer from the back and put the plug in the front usb plug.
But still no queue in the printers menu in frontview.
Can anybody help?
Added: in the messages file is this:
Jun 9 19:18:16 backup kernel: drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 2 if 0 alt 0 proto 2 vid 0x04A9 pid 0x10CA
Jun 9 19:18:16 backup kernel: USB: Canon iP3600 series printer connect.
Jun 9 19:18:16 backup kernel: usbcore: registered new driver usblp
Jun 9 19:18:16 backup kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
Jun 9 19:18:30 backup usb.agent: ... no modules for USB product 0/0/206
I reinstalled the software and the printer shows up now in frontview. The errorlog and messages show the same messages as above incl the message "no modules for USB product.
To say it short: I don't know what caused the fault, I don't know why it was cured!
Can anybody help?
1 Reply
- RXLuminaryJust want to share this forum link and it might help: https://www.readynas.com/forum/viewtopi ... =7&t=47321
