noadvertise
May 21, 2013Tutor
Pro 6 vs RNDP600E ?
Hey all, trying to learn from these forums, but i keep getting confused on model terminology. I used to think Pro 6 was referring to what I have, but now I'm not so sure. Lots of topics on pro6 and ...
fifer55
May 21, 2013Apprentice
I will have something like I do here:
viewtopic.php?f=113&t=70691
and here:
Obviously the above is for an Ultra 6 Plus, which is similar HW than the Pro Pioneer. Once I complete backing up my ~7TB's of files, I will also upgrade my Pro Pioneer with pictures and everything. My signature has the exact products I am using. I had the same learning curve as you, so it should be helpful.
and here:
