cguers
Feb 13, 2011Aspirant
Pro 6 vs Ultra 6 Plus
I am a little confused and don't really know which model to choose. What are the main differences between the Pro 6 and the Ultra 6 Plus? I see that the Pro can be integrated to Active Directory a...
mdgm-ntgr
Feb 13, 2011NETGEAR Employee Retired
Note that whilst the Pro 6 e.g. RNDP6310-200 has a faster CPU than the Ultra 6 Plus, the Pro e.g. RNDP6000-100 does not.
Yes it is difficult to compare between the home and business lines with the separate comparison charts. Printing them out could be a good idea.
Good plan. I'd use NFS for the first backup, then switch backup job properties to use Rsync for the incrementals.
