Muñoz's avatar
Muñoz
Pro Pioneer Edition dead.
 Hi,I have a Pro Pioneer Edition and i cannot reach it any more, when I start the NAS the display only shows Readynas and the network port leds are off,I tried to reboot it manualy with a peaper clip but it dous not react on it, when I push the off switch one's it shuts down immediately.
The last reports I got from the nas was that the temperature was to high.
Is there a way to save my data?
  • kohdee's avatar
    kohdee
    Administrator
    Not sure if your issue is disk related or chassis related.
    If you take out all of your drives and start the chassis, does it complain about not having disks on the LCD or does it still stay at Welcome to ReadyNAS LCD message?
    Did you get any other alerts?  Was the temperature CPU or disks?
    If your ReadyNAS is responsive when there are no disks inside by telling you it has no disks, then it might be an issue with your disks.
    If your ReadyNAS is still unresponsive, something may have happened to the hardware.
    • Muñoz's avatar
      Muñoz
      Thanks for your quic response I took all the disks out and it wanted to boot, but then it seed ERR no disk, so I think it must be the disks.
      What is the best thing to do now.?
      I have 5 disks, and they where is x-raid2.
      • StephenB's avatar
        Well, the system needs a lot less power w/o the disks, so it still might be the PSU.
        Did you test the drives with vendor tools (seatools for seagate, lifeguard for western digital)?
  • The display says "ReadyNAS" by default as long as it's getting 5V.  Most likley culpret is the power supply, but it could be something else (RAM, CPU, etc.).  As was suggested, try without any drives and then with a spare drive.  Next to try would be a standard ATX power supply if you have one handy.  All the connections are the same, it just won't fit in the chassis.  If that fixes it, there are other threads on where to get a replacement supply that will fit.  If that doesn't fix it, you'll need a VGA header connection to observe BIOS messages as it poowers up.
ProSupport for Business
