debm's avatar
debm
question about HDD Freecom XS
Hello
I am new here and I am interested in buying a READYNAS 102, however I am thinking of using one HDD Freecom XS (for the moment this is an external HDD but I
would recover the Freecom drive) 2 TB.  Does anybody have any experience on this ?  or any kind of advise would be welcome
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi debm,
    Are you going to use this HDD as the main (internal) drive? or to use the said drive and recover its data using the RN102? If this is what you meant, here's a post that you can refer to.
    Looking forward to your response.
    Kind regards,
    BrianL
    NETGEAR Community Team
    • StephenB's avatar
      Use the Freecom as your backup (and yes, you do need a backup).  Not all drives work with RAID, and Netgear will deny support if the drive isn't on their published hardware compatibility list.
      The best option is to get a new drive for the RN102 - ideally a drive designed for NAS.  I recommend the WDC "red" drives, though other posters here have had good experiences with the Seagate VN drives.  Don't get the Seagate DM drives (or the Seagate archival drives).
      Note that if you want RAID redundancy you'll need two drives of equal size.
      • debm's avatar
        debm
        thanks for the reply very usefull to me
ProSupport for Business
