Hewlas
Dec 04, 2017Follower
R104 drive 4 warning
I am getting a message that details a possible failure of disk 4 on my readynas system. I have 4 drives and they are all 2 tb. I can physically change the drive but how do I transfer the data that is on disk 4 to the new drive?
Thanks for any help.
- What's your raid? If you are in X-raid mode, NAS creates a raid5 volume with all the four disks, you can hot-remove the disk4 out , then hot-insert a new disk, NAS will sync automaticlly. Thank you!
1 Reply
- yxueNETGEAR ExpertWhat's your raid? If you are in X-raid mode, NAS creates a raid5 volume with all the four disks, you can hot-remove the disk4 out , then hot-insert a new disk, NAS will sync automaticlly. Thank you!
